Home > Technical > 2022 P300 Oil Change
Scrotiform
United States
Post #1035950 29th May 2024 4:20am
TexasRover
Although it is satisfying to see hot oil gush out of the drain, sucking it out is way more easy and convenient. I had a few LR3 and 4 and they have skid plates which makes it even more cumbersome to get to the drain plug so I bought a large sucker. One day I tried to see how much was left behind the drain plug and not a drip came out.
In the end if you change frequently enough there will be no sludge and you just replace 99% of the dirty oil with new fresh oil. So for your convenience I would say extract the oil by suction and replace with correct oil and you be doing your engine a huge favour.
Post #1035953 29th May 2024 5:12am
Defendit..
Netherlands
Make it yourself easy and install the Fumoto drainplug .
See this thread on Landrover forums.com
I did make one hole wider in the under plating for even quicker draining with a tube.
https://landroverforums.com/forum/2020-def...post884592 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1035962 29th May 2024 7:58am
