![]() | Home > Maintenance & Modifications > Both Sides At Once? |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 196 ![]() ![]() ![]() |
Glad you got it sorted!
The diagrams show a washer under the bolt and the notes for the part explain that they're used to up KA (1993). https://www.lrworkshop.com/diagrams/land-r...cs_52911#3 A lot of the pre-puma diagrams span 87 to 06 variations in one diagram. My ultimate aim is to re-engineer them into more obvious groupings of spec, e.g pre/post 300Tdi to take out some of the complexity/confusion LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 ![]() ![]() ![]() |
So it does! That’s presumably where the confusion arose. It’s an ‘83 vehicle so the bolt/washer arrangement might have been correct, however the new brakes kit came with flanged bolts. So the “mechanic” had used more parts than required. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
