Home > General & Technical (L663) > Advice and views on a D300 and DPF's
mlambton
Hi
Im getting close to chosing my next vehicle. For the last few years ive had a 2015 SDV8 rangerover. About 50% of my annual 12000 miles is under 5 mile trips. My worry with an L663 D300 is whether I wil have problems with the Diesel particulate filter (DPF) clogging.
I would say that my current Rangerover hasnt had an issue (though many have) and I accept i need to change the engine oil and filter every 6 months currently due to the dilution effects on the engine oil from the failed regenerations.
Any perspectives would be appreciated
Post #1035738 26th May 2024 3:09pm
nebc100
Luxembourg
My personal opinion is that I would not touch a diesel if I were doing so many short trips.
That is why I went for the P400
Post #1035743 26th May 2024 3:50pm
BrickBox
I don’t think these modern diesels are worth the hassle.
Go for a petrol. 2008 2.4 110 Utility Station Wagon XS.
Post #1035746 26th May 2024 4:28pm
martinf
I agree with changing to petrol. I had a 2015 Range Rover and found the endless oil changes because of oil dilution expensive and tiresome.
Much happier with my P300 Defender.
Post #1035750 26th May 2024 5:18pm
lightning
l've got a new Defender D250
A lot of my driving is short journeys and l've had no issues at all with it. Occasionally l've noticed it regenerates the DPF (the idle speed is slightly higher)
l've had no oil dilution, the oil has been checked and replaced twice. l think the D250/300/350 six cylinder lngenium engine is designed better with regards to the DPF.
Post #1035753 26th May 2024 5:53pm
DFNDER
Australia
It's the reason I went to P400 as well. DPF, adblue, EGR, frequent oil changes, oil dilution etc was enough to put me off diesel.
Post #1035772 26th May 2024 11:36pm
mlambton
Thank you for your perspectives they are much appreciated.
I think Im tending towards the petrol P400e option. The fact that many of the major manufacturers are ditching the Diesel option and UK cities are increasingly ramping up the amount of low emission zones also nudges me further towards the petrol hybrid option.
Post #1035780 27th May 2024 7:31am
Soup Dragon
DPF is definitely a pain. You can be 20-30 mins into a longish run and then without warning (no lights on dashboard), the mpg halves for maybe 5 minutes (you can see this clearly on the instant mpg display) until DPF clears. This happens to me on almost every journey and puts a circa 10% dent in my fuel economy. I’m going to ask the dealer about whether this is normal when it goes in for a service but that won’t be for a while. This has never happened on any adblue equipped diesel car I’ve ever owned.
Post #1035781 27th May 2024 7:33am
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Go for a petrol.
I agree. Given a choice it’s a no brainier. WARNING.
This post may contain sarcasm.
Post #1035783 27th May 2024 8:04am
Moo
Ukraine
My D250 does mixed driving but have never noticed the DPF regenerating. Confused Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1035790 27th May 2024 9:06am
J77
The only way I know mine is going through a regen is the more throaty exhaust note, can’t say I’ve noticed a significant drop in fuel economy. 24MY 90 D250 HSE, Tasman Blue
Post #1035840 27th May 2024 6:51pm
lightning
Same here, DPF regenerates occasionally and after 12,500 miles the Adblue is still saying 5,000 miles remaining.
When the DPF regenerates l notice a drop in the instant fuel economy readout for a few minutes. But it certainly doesn't happen every journey.
ln city driving l get 26-28mpg and on a longer run around 40mpg.
Post #1035843 27th May 2024 7:03pm
lightning
Zed wrote:
Go for a petrol.
lt depends on what you are using the vehicle for. l couldn't live with under 20mpg. l also prefer petrol over diesel but l had a petrol version on loan and managed 18mpg with my kind of use.
Post #1035844 27th May 2024 7:06pm
mlambton
I’m thinking that the p400e would be a better option over diesel given half my mileage would be daily short trips of 3-4 miles each way. I think this type of driving is probably the worst profile for a diesel and may be the PHEV sweet spot?
Post #1035853 27th May 2024 8:36pm
lightning
You're probably correct as with those short journeys you'll probably be on electric power and won't use any fuel at all.
As l said, everyone is different. l tow a caravan and can still achieve over 25mpg with my D250. The Commercial version is only available with the MHEV diesel
Post #1035857 27th May 2024 9:09pm
