Home > Puma (Tdci) > 90 rear folding seats, replacement nuts and bolts
mpetzsch
Took a huge amount of effort and PlusGas to get these all off and the nuts on the underside got stuck in the socket multiple times. Can anyone tell me what spec replacement nuts (with built in washers?) I need to replace them? Bolts would be great too but they seem less of a state. Thanks!
Post #1035604 24th May 2024 5:54pm
Dinnu
I thought all seat nuts are welded to the stiffener plate. As I recall only flange nuts on the seat belt brackets, M8s. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1035609 24th May 2024 6:53pm
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
The bolts from the seat frame went through the wheel arch and had these nuts on the other side ( see photos which seem to be in my gallery)[/img]
Post #1035610 24th May 2024 6:56pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I just replaced my rear seats and the nuts are indeed welded to the body, at least on mine I only had to use a Torx bit inside the cabin to get all the fixes out.
https://parts.jaguarlandroverclassic.com/p...and-rover/
I ordered new hardware and fixes as needed directly from LR.
Good luck
Post #1035648 25th May 2024 6:59am
mptzs90
Thanks - am so confused! My seat hinge points have bolts welded to the fixing points which could through the tub into the arches. And there’s no way they were coming out without removing the nuts in the arches. I also can’t find this in the parts pictures though.
Post #1035650 25th May 2024 7:02am
mptzs90
They look exactly like these- but I can’t find an official part: https://www.ebay.co.uk/itm/171942808926?va...gXEALw_wcB
And this refers to the nuts on the underside… so I’m not totally crazy: https://www.aulro.com/afvb/90-110-130-defe...seats.html
Post #1035654 25th May 2024 7:33am
Dinnu
Could they be aftermarket seats? What year is your Defender, and do you have the stepped tub? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1035658 25th May 2024 8:12am
mptzs90
2015 my. I don’t think they’re aftermarket- it’s registered as a station wagon xs. And not a stepped tub
Post #1035660 25th May 2024 8:28am
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
It is actually very straightforward: There are indeed 2 nuts on each side to be removed from the wheel arch. All the others are the torx bolts that were mentioned and that you can remove from the inside.
After removing the lower attachmens and the seats I put back all the torx bolts to close these holes and use some (M13?) bolts I had lying around with plastic washers in the remaining holes to close them.
I have the seats out and made some pictures. Will upload them later today.
Post #1035671 25th May 2024 9:51am
mptzs90
Exactly the setup I have. I can’t find the parts for the nuts on the underside though. Have replaced with flanged stainless steel for now as the old ones were a mess and not holding.
Post #1035763 26th May 2024 8:35pm
Millerdark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Fuji White
Post #1036995 10th Jun 2024 7:15am
