Home > Puma (Tdci) > 2009 2.4 TDCi ECU not communicating
Page 3 of 3 <123
Martin
Site Admin
All Pumas have a 10AS alarm unit, fobs or not.
Do the dash warning lights stay on or go off when you run the starter?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035350 21st May 2024 8:19pm
Ianh
I just noticed on the picture of your instrument cluster that the green trailer light is illuminated. I’ve never noticed that illuminating unless I have a trailer light board connected and indicators on. Probably a red herring but thought I would highlight.
Post #1035351 21st May 2024 8:25pm
Landy addict
Ah ok then I still have that original one in there & connected will the fact that I changed the ignition barrel affect that.
This is the way it looks when running,
maybe a bit late to mention this but I have an EGR blanking plate in & de-cat exhaust manifold once I get it running I was going to plug in the Alive Artic remap interface so that they can re-map it for me. Would that be causing any issue
Ianh Trailer Light might be on as I am still wiring up the towbar.
Post #1035352 21st May 2024 8:45pm
Ianh
have you blanked the EGR already? if so and not had the EGR mapped out then I suspect that can cause issues. However they would only really manifest after the engine has warmed up and running at higher revs. Where as a stuck open EGR can cause engine stalling after starting
Alternatively, I would double check you have the right wires on the right terminals of the ignition switch, then check the wires are crimped well and wiring connectors are tight on the ignition terminals.
Post #1035354 21st May 2024 9:37pm
Martin
Site Admin
Do the dash warning lights stay on or go off when you run the starter? Literally when you turn the key?
The trailer lamp stuck on indicates something going on there. Should only be on when indicating and the additional trailer lamp load detected, or with hazards on.
Even if the wrong module/relay fitted in the wrong place under the steering wheel and bridging something there should be no voltage present at the flasher unit socket to allow the trailer lamp to come on.
When engine running you appear to have a MIL, and alternator lamp on (unless it's starting and stopping so quickly that these don't get a chance to go out). Do either of these actually go out?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035356 21st May 2024 10:09pm
Martin
Site Admin
Now you have ECU powered up, get code reader on, clear all faults to start from a 'clean slate'.
Then key off, key back on and try and start.
Now any codes you read will be 'true' codes.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035357 21st May 2024 10:15pm
Landy addict
when I turn the key to start after the glow plug symbol goes out the starter turns over & the oil light goes out before it actually starts (doesn't turn over for long before it starts)
I have the LED lights indicators & so on this is the flasher relay (top left) for the LED's I adjusted the screw on top now the trailer light goes out as it should.
Post #1035360 21st May 2024 10:46pm
Landy addict
Tried a small code reader on & no fault codes appeared, trying to get hold of the guy with the professional code reader to come out now that you guys have ironed the other issue out for me.
Post #1035361 21st May 2024 10:56pm
Martin
Site Admin
OK if the cluster stays on and you see lights go out then that's fine, ignition switch wired up ok.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035362 21st May 2024 10:59pm
Landy addict
Well I am really happy now went out this morning put on another new fuel filter blead it again & now she runs Very Happy the tank had been drained well I was rebuilding the 90 so I think the new filter got gunked up & was choking it.
cant thank you guys enough for all the fault finding advise that got me to this point Thumbs Up
Post #1035376 22nd May 2024 10:28am
Martin
Site Admin
That's great, well done.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035377 22nd May 2024 10:38am
Page 3 of 3 <123
