Home > Td5 > exact(ish) position of rear washer jet nozzle |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1819 |
On my Puma 90 it is central and the nozzle is only just 2mm maybe above the gutter, hope the pic helps
Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
3rd May 2024 2:47pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 110 |
Brilliant, thank you Rob
3rd May 2024 2:49pm |
Click image to enlarge Thanks again Rob. 👍 Not sure if I need a new thread though?….. unusually, the flow is too strong (50 plus males 🤣) and the “squirt” hits between the rear wiper and the spare wheel! I’ve tried to adjust the jet “eyes” but they don’t seem to move. Any ideas please from you lot? |
3rd May 2024 11:00pm |
Did someone inadvertently sell me a front jet maybe? No idea really. 🤔
3rd May 2024 11:04pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 913 |
Get yourself a pin or needle, stick it in the hole and rotate the ball jets towards the window. Front windscreen squirters are about an inch and half longer. You’d know, as it won’t fit
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
4th May 2024 9:14pm |
Cheers, all sorted. I was surprised by how stiff the jets were to move - needed a good quality needle, a pin just bent.
5th May 2024 1:30pm |
