Home > Td5 > exact(ish) position of rear washer jet nozzle
110Matty
Hello,
One of the mods i have done to my basic hardtop 90 is to fit a rear wipe and wash system, which didn't come fitted from factory. It's all complete at front, pump, pipe, dash / switch etc and tested, ready for drilling and fixing into the rear panel above the door. I'd like to follow the factory position for the jet / nozzle if possible, but I can't find it online. I'm guessing it's in the centre of the rear panel (width ways / horizontally), but I'm unsure how close it is from the rear gutter (height wise). I was surprised that there was no hole / grommet, like there was for the rear wiper motor in the back door. Anyone willing to do a quick measure up please?
Post #1033719 3rd May 2024 2:38pm
CarMan
On my Puma 90 it is central and the nozzle is only just 2mm maybe above the gutter, hope the pic helps
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #1033720 3rd May 2024 2:47pm
110Matty
Brilliant, thank you Rob Thumbs Up
Post #1033721 3rd May 2024 2:49pm
110Matty
Thanks again Rob. 👍
Not sure if I need a new thread though?….. unusually, the flow is too strong (50 plus males 🤣) and the “squirt” hits between the rear wiper and the spare wheel! I’ve tried to adjust the jet “eyes” but they don’t seem to move. Any ideas please from you lot?
Post #1033763 3rd May 2024 11:00pm
110Matty
Did someone inadvertently sell me a front jet maybe? No idea really. 🤔
Post #1033764 3rd May 2024 11:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Get yourself a pin or needle, stick it in the hole and rotate the ball jets towards the window. Front windscreen squirters are about an inch and half longer. You’d know, as it won’t fit Thumbs Up
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1033822 4th May 2024 9:14pm
110Matty
Cheers, all sorted. I was surprised by how stiff the jets were to move - needed a good quality needle, a pin just bent.
Post #1033860 5th May 2024 1:30pm
