Home > Modifications & Maintenance (L663) > Disabling emergency lane keep assist
Retroanaconda
I’ve noticed these settings in the CCF:
MultiCAN-498 LaneKeepAssistLKA
 - LKA fitted
MultiCAN-699 ELKARE
 - Fitted
MultiCAN-706 LKARE
 - Fitted
What’s the chance of toggling any of these disabling ELKA? It’s quite annoying from time to time.
Post #1032329 21st Apr 2024 5:37pm
lightning
You could be the one who finds out!
Why not try it and see what happens. You can always restore the original settings if it doesn't work.
Post #1032435 22nd Apr 2024 7:01pm
lightning
l tried turning Multican 498 from "fitted" to "not fitted" and it came up with "emergency brake assist not available" next time l turned on the ignition.
So the two must be connected. l reset it to "fitted" and the brake assist warning disappeared.
l didn't try to change the other two settings (Multican 699 and 706)
Post #1043248 19th Aug 2024 9:36pm
