Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK
Page 28 of 42 <123 ... 272829 ... 404142>
Bps
You can fit them on but they will rub on the arches as soon as you turn a corner. Best with a lift and trimmed or bigger arches
Post #509078 28th Feb 2016 8:19pm
FortySeven
That's what I feared! Thanks Bps.
Post #509106 28th Feb 2016 9:41pm
Bps
I'll try and dig out a picture of my old 110 with 35s before it was lifted. This is my 90 with 35's on and big arches. I pulled a standard rear arch off ( had been trimmed as well) so went for the big ones as high as I could mount them. I was mainly governed by how far the snow down came down the wing on the passenger side
Out of interest how much are the 35's and where abouts?
Post #509114 28th Feb 2016 10:00pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
There is a set on eBay at the moment that I keep looking at, they have been re listed about 5 times.
Post #509186 29th Feb 2016 8:49am
FortySeven
Bps wrote:
I'll try and dig out a picture of my old 110 with 35s before it was lifted. This is my 90 with 35's on and big arches........
Thanks for the image. Makes more sense to me. The guys looking for €750 for them on Modulars. Not a bad price but they're about 6 years old. Not a lot of wear but not fresh!
Post #510187 3rd Mar 2016 12:51am
ashtonchan
Malaysia 2012 Defender 110 Puma 2.4 HCPU Indus Silver
275/70/16 Chrome modular
Post #510379 3rd Mar 2016 3:20pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Kind of weird there aren't many on 35" tyres around here
Post #513386 11th Mar 2016 10:37pm
Lucifus
OK here's a couple of different tyre/wheel/spacer/arch/defender combos I've had over the years -
285/75/16 BFG Muds fitted to factory boosts - No suspension mods, no spacers. It drove just fine. Slight rub on the chassis on full lock but this could have been easily solved with a bump stop adjustment.
Same setup as above but just with a 30mm spacer
305/70/16 Mickey Thompson muds on 16x10 et-35 offset modular. 1" rear lift on HD suspension all around.
Same as above but with wider arches fitted -
Same as above again but with 30mm spacers -
It now also has a 2" front suspension lift and 3" rear suspension lift on medium duty springs. I don't have a photo of that though.
Here's a photo of the 305's along side the 265's for anyone interested -
265/75/16 with 30mm spacers with standard military spec HD suspension
7.50 16 Goodyears (I think) on wolf rims. As collected years back from Withams - Direct release from MoD
285/75/16 BFG AT (the new ones) on 16x7 et-25 challenger steel wheels - Totally standard suspension
265/75/16 BFG Mud fitted to 16x7 et0 with 30mm spacers
Post #513474 12th Mar 2016 11:31am
Arierep
Thanks Lucifus for the variety of setups.
How would you compare them?
With só many 285/75r16 on 7j rims around, I wonder if mounting them on Wolf 6.5j rims would be such a drama
Post #513496 12th Mar 2016 12:17pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
The picture of the green 110 being pulled by the blue 110 looks ripe for a caption contest.
Post #513497 12th Mar 2016 12:23pm
familymad
76MV wrote:
I have gone for wolf wheels again but have painted them aintree green this time around. I found that my last set rusted quickly.
Comparison
That is so me.... 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #513501 12th Mar 2016 12:41pm
Lucifus
Honestly there's not a huge difference in the road driving on modern muds. The biggest difference is fuel consumption. My MoD 200tdi was doing around 31mpg with 265s. Thats dropped to 29mpg with the 305s. Personally I think 285 is the perfect size.
I've not done any serious off road with the 305's or the new 285 AT's. The new BFG AT is a pretty chunky beast though. I imagine it would perform ok.
Someone commented earlier on this thread about wide tyres aquaplaning. I've honestly never had it with any of these setup even whilst driving at motorway speeds through standing water/extreme rain.
I'm not sure if 285 is recommended on a 6.5" rim - I think 285 on a 7" rim is pushing it a bit. Normally the tyre manufacturers will state on their website the min and max width rim that the tyre can be mounted on. I would check.
Post #513619 12th Mar 2016 6:47pm
Arierep
Thanks again Lucifus,
I was dead set on 255/85R16 tyres, but then started to see pics of Defenders 90s with 285/75R16 and got confused. Also, trying to go to northern Africa in a few months and think the volume of the wider tyres might be an advantage on the dunes.
The thing is that I just love Wolf rims, even if they are 6.5 wide. Most brands specify a minimum rim of 7.5 for the 285s.
Guys on the US seem to mount those tyres on 6.5 rims all the time, and the Ihana expedition guys done like 30000km with 285 BF mts on Wolfs without problems...
Post #514381 14th Mar 2016 10:42pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Lucifus wrote:
Love those arches. Where can I get them from and what ET should I look for acording to standard, to achive such look? I would like to got for Mach 5 -would need spacers than, right?
Also - If I wanted 35" tyries would 2" lift be enough?
:thumbsup:
Post #515665 18th Mar 2016 10:58am
Arierep
Hi Simon.pl,
Fitting 35" tyres is not really a matter of lift, but more of limiting upward travel with bigger bump stops.
You can have a 2 or 3 inch lift, but if upward travel stays the same then you might have some rub.
Post #515696 18th Mar 2016 12:29pm
