Home > Maintenance & Modifications > 265 75 16 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3384 |
Which vehicle are they on?
11th Apr 2024 9:11pm |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 134 |
Sorry..... 110 puma crew cab
11th Apr 2024 9:16pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
From experience, regardless of tyre type, at this sort of size I would run 30-32psi all around and then watch tyre wear. If you rotate the wheels every few thousand miles at this pressure you should get a pretty even/flat tread wear profile that maximises tyre life. If running heavily loaded or when towing I go up to about 34Fr/38-40Rr but reduce pressure back down once the trip is done.
12th Apr 2024 12:27am |
Also need to bear in mind that these tyres are only speed rated (K) to 68mph which is significantly less that the published speed of your truck.
12th Apr 2024 6:50am |
