Home > Maintenance & Modifications > 265 75 16
Naycrx
265 75 16
Good evening
What tyre pressure would you run for a stt pro 265 75 16 tyre. Road use only really
Thanks
Post #1031306 11th Apr 2024 9:00pm
camelman
Which vehicle are they on?
Post #1031307 11th Apr 2024 9:11pm
Naycrx
Sorry..... 110 puma crew cab
Post #1031310 11th Apr 2024 9:16pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
From experience, regardless of tyre type, at this sort of size I would run 30-32psi all around and then watch tyre wear. If you rotate the wheels every few thousand miles at this pressure you should get a pretty even/flat tread wear profile that maximises tyre life. If running heavily loaded or when towing I go up to about 34Fr/38-40Rr but reduce pressure back down once the trip is done.
Post #1031313 12th Apr 2024 12:27am
camelman
Also need to bear in mind that these tyres are only speed rated (K) to 68mph which is significantly less that the published speed of your truck.
Post #1031320 12th Apr 2024 6:50am
