![]() | Home > In Car Electronics (L663) > Siri refusing to navigate |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Probably some iPhone setting turned off, thus not allowing access.
There are so many it’s common to not know which it is at times. ![]() Needs good access to GPS (line of sight to Sattelite), Location services on, audio up all the way, do not disturb off, maybe a good idea ensuring 4/5G is available and probably Siri permissions on. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 297 ![]() ![]() |
Thanks for the reply. All your suggestions were set anyway, and yes, I thought iPhone settings but nothing has been changed and CarPlay starts up ok and is onscreen, Siri starts up on demand and responds to the question but then declines to provide the result due to being ‘in the car’. I guessed it might be iPhone’s Focus interfering due to driving but that is set to ‘manual’ so shouldn’t be on.
Only things that have changed since I last used this feature successfully has been iPhone updates and the LR OTA update to 4.1.1. I’ll keeping looking…… |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
Pivi latest update is 4.1.3 , this may or may not fox your issue once you are on the latest version MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Trouble is, that sometimes updates or auto updates can wipe existing settings.
And then they sometimes need re-setting, and that’s only after you’ve realised something isn’t working. And seeing as LR have updates and Apple, then there are two parallel updating software versions. Just something to bear in mind. ![]() ⛽️🛢️⚙️🧰💪 |
