![]() | Home > Maintenance & Modifications > 265/75/16's on Stock 110 suspension ? |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
My experience of 285's on the 90 was good overall. Now got them on my 110 and pretty much as pleased. My turning circle doesn't seem to have been too badly affected......they're not great in that department as it is though!
![]() 2011 110 XS DC Stornoway Grey |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
Hmmm, ok i think the 265's will be the way to go then ![]() |
Guys, what would you say about getting extended bump stops ? Seen a few people talking about getting them when they got a bigger tyre size ?
Pretty sweet 90 ![]() ![]() ![]() |
i had the same et up on my td5 90. Guess whats going on the 110 ![]() |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Some picyures in my gallery with 265s on my 90. Didnt need to adjust bump stops.
Speedo is very slightly out by a couple of mph... No Spacers, Boost Alloys. BFG ATs Ideal IMHO Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I am on 265 on Blindos with no issues
It's the same with 265's on spacers ![]() ![]()
That would only be necessary for larger diameter tyres. 265/76/16's are essentially the same diameter as standard 235/85/16's. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17661 ![]() ![]() ![]() |
Personally I wouldn't use spacers with 265s but would (and do) with 285s.
Not sure why you would want to extend the bump stops unless you've lifted the suspension - you'd just reduce suspension travel. |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Yes it's a side exit exhaust, full SS system from Twisted Performance. Sounds lovely!! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Interesting, with 285s on my 110 my speedo seems to be as close to spot on as I can measure (both timing off motorway distance markers and with a radar gun at a fixed object). The effective rolling diameters of a 265/75 and a 235/85 are so similar as to make a negligible difference (the 265/75 is actually smaller than the stock 235/85) so if anything the speedo (on a 110 at least) should under-read more than before with 265/75s. The 285/75 is approx 5% larger than the 235/85 and is would be highly unusual for a modern speedo to be accurate to +0%/-5%, i.e., to over-read by less than 5% anyway (since manufacturers are allowed to over-read by up to 10% but not to under-read at all, all speedos tend to over-read by around 5%). The result of this is that with 285s my speedo seems to be very accurate indeed. Is a 90 speedo calibrated differently to a 110? I presume that it must be set up for smaller tyres. Can this be reprogrammed with nanocom/BBS etc? |
