Home > Maintenance & Modifications > 265/75/16's on Stock 110 suspension ?
Page 2 of 2 <12
scottish110 wrote:
Would it work without the 30mm spacer or would the turning circle not be as good ?
With 285s on Boosts but without the spacers, the turning circle is ideal for orbitting small planets but not much else (see also Pom's post above).
You can live with it, but negotiating car parks, and even some mini roundabouts, can be interesting and it really isn't convenient. With spacers, the original tunring circle is restored and there are really no adverse effects.
Be aware that with 285 MTs - especially with spacers - the outside of your truck will get covered in crud like never before. If you are a clean truck person, don't do it! if you think it looks better with mud, go for it, but keep the windows shut off-road!
Post #100096 15th Nov 2011 4:45pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
My experience of 285's on the 90 was good overall. Now got them on my 110 and pretty much as pleased. My turning circle doesn't seem to have been too badly affected......they're not great in that department as it is though! Smile Mark
2011 110 XS DC
Stornoway Grey
Post #100098 15th Nov 2011 4:59pm
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Hmmm, ok i think the 265's will be the way to go then Laughing ! So would you recomend using a spacer with them ?
Post #100100 15th Nov 2011 5:09pm
scottish110
Guys, what would you say about getting extended bump stops ? Seen a few people talking about getting them when they got a bigger tyre size ?
Post #100101 15th Nov 2011 5:10pm
scottish110
MuddyMarky wrote:
scottish110 wrote:
Think 285's would stick out to wide guys ?
A couple of pics of the 285 BFG muds on my 90 in my gallery chap.
Pretty sweet 90 Thumbs Up ! Nice pooch too Smile ! Im going to have to think about getting some sort of ramp for my two so they can get into the back Rolling with laughter !
Post #100102 15th Nov 2011 5:13pm
T1G UP
MuddyMarky wrote:
I had 285's on Boosts on my 90 and didn't get any rubbing etc at all.
i had the same et up on my td5 90.
Guess whats going on the 110 Thumbs Up
Post #100105 15th Nov 2011 5:22pm
robpenrose
Some picyures in my gallery with 265s on my 90. Didnt need to adjust bump stops.
Speedo is very slightly out by a couple of mph...
No Spacers, Boost Alloys. BFG ATs
Ideal IMHO Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #100117 15th Nov 2011 5:56pm
mick
I am on 265 on Blindos with no issues
Post #100169 15th Nov 2011 9:05pm
It's the same with 265's on spacers Rolling Eyes
That would only be necessary for larger diameter tyres. 265/76/16's are essentially the same diameter as standard 235/85/16's. Darren
Post #100209 15th Nov 2011 10:59pm
Personally I wouldn't use spacers with 265s but would (and do) with 285s.
Not sure why you would want to extend the bump stops unless you've lifted the suspension - you'd just reduce suspension travel.
Post #100225 15th Nov 2011 11:54pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
scottish110 wrote:
BIGFOG wrote:
scottish110 wrote:
BIGFOG wrote:
Ive got Coopers on Silverline rims, 0 offset and they are also fine, even at full articulation.
Got any pictures mate ?
Course! Thumbs Up
Thumbs Up Really works well the black on grey.... Is your exhaust coming through the body on the side ?
Yes it's a side exit exhaust, full SS system from Twisted Performance. Sounds lovely!!
Post #100551 17th Nov 2011 4:11pm
Ideal IMHO
Interesting, with 285s on my 110 my speedo seems to be as close to spot on as I can measure (both timing off motorway distance markers and with a radar gun at a fixed object).
The effective rolling diameters of a 265/75 and a 235/85 are so similar as to make a negligible difference (the 265/75 is actually smaller than the stock 235/85) so if anything the speedo (on a 110 at least) should under-read more than before with 265/75s.
The 285/75 is approx 5% larger than the 235/85 and is would be highly unusual for a modern speedo to be accurate to +0%/-5%, i.e., to over-read by less than 5% anyway (since manufacturers are allowed to over-read by up to 10% but not to under-read at all, all speedos tend to over-read by around 5%). The result of this is that with 285s my speedo seems to be very accurate indeed.
Is a 90 speedo calibrated differently to a 110? I presume that it must be set up for smaller tyres.
Can this be reprogrammed with nanocom/BBS etc?
Post #100554 17th Nov 2011 5:00pm
Page 2 of 2 <12
