Home > Td5 > Centrifuge Oil Filter Housing Seal
andylee
Hi guys, Ive got to pull the Centrifugal Oil filter housing and drill out a broken bolt for the cap, and yes Ive always been very careful not to overtighten these but it somehow it locked itself solid and subsequently broke leaving half the nut in the thread.
My question here is about the O ring seal to the oil cooler, part number ERR7098.
I cant find a genuine part for this anywhere as I always try to stick to genuine parts especially critical parts and parts that mix with heat and oil. Should I be concerned about using a non genuine seal ? Or doesn’t it really matter too much? I could just re use the one set in place as it wasn’t leaking before but it would seem like a good idea to replace it. I don’t really want to take it off again because Ive used a £1 seal but is there an alternative that anyone could recommend?
Many thanks
A
Post #1030211 2nd Apr 2024 3:07pm
4RF RDS
New centrifugal filters always come with a new seal. LR part number for the seal alone is ERR7247 Thumbs Up
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1030213 2nd Apr 2024 3:17pm
Screbble
Sounds like an all too common problem - good luck with the repair - but make sure that none of the detritus or swarf gets in the housing.
I’d stick with the original o ring. It’s either fine or it’s not if you know what I mean.
All of the rotor filters I’ve had come with a new seal - I’ve never seen them sold separately.
Good luck 👍
Post #1030214 2nd Apr 2024 3:19pm
andylee
Sorry guys just to clarify, i have to remove the filter housing from the the oil cooler so I can drill a bolt out and the seal Im looking for is out the side of the filter housing where it joins to the oil cooler and is what looks like a 3cm O ring. Part ERR7098 Not the seal that comes with the filter for the lid.
Thanks
A
Post #1030218 2nd Apr 2024 3:31pm
4RF RDS
D’oh! The limitations of text! Rolling with laughter
The two o rings which only seems to come with the oil cooler assembly? I am sure microcat would have them listed but obviously not here in LRWorkshop. 🤷‍♂️
https://www.lrworkshop.com/diagrams/land-r...lter_53224 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1030220 2nd Apr 2024 3:39pm
You will find it extraordinarily difficult to drill out a sheared bolt without damaging the housing since the bolt is steel and the housing light alloy. I would suggest trying to find a second-hand housing (they turn up on eBay etc) to refurbish and swap them over.
The threads in the holes are a very common failure and it is sensible to Helicoil them before fitting the housing. Helicoiled they will be many times stronger and will last forever.
Post #1030221 2nd Apr 2024 4:09pm
rustandoil
It's the bolt design that's the problem with the housing top.... The bolt is shouldered so that it's retained with the cap... Unscrewing the bolt to remove it damages the thread, it's all downhill from that point 😕
Post #1030225 2nd Apr 2024 4:22pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Just make sure it's right as otherwise you can loose 6 litres of oil very quickly on your way into Bournemouth one morning 😅 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1030226 2nd Apr 2024 4:24pm
Screbble
Thanks
A
Apologies my mistake. Hope all goes well Thumbs Up
Post #1030232 2nd Apr 2024 4:57pm
andylee
Thanks for your responses, following Blackwolfs wisdom I have sourced a refurbished housing from Turner Engineering that has already been Helicoiled, I think it would of always bugged me as a bit of bodge fix and now hopefully one less thing to worry about during its service and longer runs. lets hope the removal of the old unit goes smoothly as there is no aircon unit above it i'm hoping it will lift out without too much of a fight.
Gave up on trying to source an original O ring ERR7098 for the Oilcooler seal and just gone with the best I could find,
thanks everyone
A
FYI - It did manage a 300mile round trip at the weekend with no leaks and only one bolt holding the cap on but that might of just been luck, not sure how long that kind of luck lasts for...
Post #1030250 2nd Apr 2024 5:58pm
I've met examples where the hole has been drilled out to clearance size and a nut has been fitted under the lower housing. It's a bit of a bodge but works.
Post #1030268 2nd Apr 2024 7:21pm
34064
Always worth having a long M5 bolt about and washers and Nylocs just incase it strips during a service 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1030277 2nd Apr 2024 7:57pm
NickMc
I have seen that too Rolling with laughter I’ve done it to get a farmer out of a pinch for a while as well….i wasn’t proud of myself Rolling with laughter
Post #1030305 3rd Apr 2024 12:58am
andylee
Job done...
So today I extracted the centrifugal oil filter housing with some effort but no major drama, fitted the reconditioned (helicoiled) unit which slipped back into position. Drilled out the broken stud in the old one and fitted a long m6 and nut to keep as a spare. And thats that done...
Look forward to discussing the next Land Rover maintenance event with you all
and thank you all for your comments and advice.
Post #1030723 6th Apr 2024 3:00pm
