![]() | Home > Maintenance & Modifications > ORE Wheel Carrier Rattle |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 ![]() ![]() |
You aren’t alone, I have 33’s and it vibrates way more than I think it should. I have window grills in the back and it’s very concerning how much you realise it moves. I wouldn’t be surprised to see them start cracking due to fatigue. I got a good deal on a used on, and I’m still disappointed with it. Would be extremely disappointed if I’d paid the full price for one.
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1048 ![]() ![]() ![]() |
I have standard wheels on mine, so mostly happy with the Ore carrier. Main downside is that there's rust appearing after just 2 years despite the claims for their special coatings.
Sussex110 Member Since: 18 Jun 2021 Location: Sussex Posts: 23 ![]() ![]() ![]() |
Similar here. Very happy overall but there is rust appearing on the plate that attached to the rear door which is disappointing given the coating claims.
MCGreen Member Since: 24 Feb 2024 Location: Worcester Posts: 11 ![]() ![]() ![]() |
I was going to buy one but held off due to reports of long wait times and poor customer service.(which doesn't seem to be so much of an issue anymore) But now concerned about rust and moving when a large wheel is fitted.
Guess I will go for the Masai heavy duty now, shame because didn't want to drill holes in the back and not sure I like the off-centre position but at least I could see out rear window and get to the handle ![]() Defender 90 HT XS 2.2 Puma Aintree Green 2010 4.4 TDV8 Autobiography - Galway Green - Sand Leather Clear Glass |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Aren't these on taper bearings? Can the bearings be nipped up a bit to reduce movement? > 110 XS Double Cab
In my case the movement isn’t in the bearing, it’s in the actual arm that it bends, wish it was as simple as nipping the bearings up. I did speak with one of ore’s “approved installers” about it and he agreed that it is a problem but seems like it’s something ore don’t want to know about.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 584 ![]() ![]() ![]() |
Have a look at https://www.nakatanenga.de/en/optional-equ...w/ht?c=334
chrismack85 Member Since: 25 Feb 2020 Location: Birmingham Posts: 65 ![]() ![]() ![]() |
Chris here from ORE - news to me none of our approved installers have mentioned the arm bending!? |
Chris here from ORE - have you seen he trouble shooting section in the instructions? |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 ![]() ![]() ![]() |
Sorry to Hijack, but Chris is there any plan's to make the Modular Cargo system again? I can't find anything remotely as good and would love to have an upper bulkhead set
I've had the ORE wheel carrier on my Defender for a couple of years. I recently noticed some wobble. I removed the spare wheel to take the load off, removed the two plastic caps and tightened up the two big (30mm) nuts. Not sure if there is a specific torque. Wobble gone
Send you a PM - sorry guys flat our here and I don't often come on this forum best to email |
