![]() | Home > Maintenance & Modifications > Should I remove the MT82 gearbox on my driveway…? [Updated |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 681 ![]() ![]() |
Hi BW.. I'm aware of the option you mentioned. And I'll try and explain why I choose to remove the gears when I fit or for that matter remove the transfare box.. Its not difficult and doesn't take long.. Its not just a case of getting the splines lined up.. The bore is a very close fit on the splines and the shaft has to engage the splines over a few inches.. The box has to be perfectly aligned axially for it to slide on or it can bind up and stick /jam on the shaft if the alignment isn't spot on.. In my first attempt that was made worse by having the transfare box rigidly mounted on a trolly jack fitting and the whole assembly of box and jack was not moving easily on the surface I was working on.. So getting it aligned not so easy... With the gears out you still have to be careful not to damage the oil seal but you have a lot more scope for getting it on if your alignment isn't spot on..and as with the gearbox a piece of studding helps locate it.. That's what I experienced anyway and rather embarrassingly I've damaged a gearbox output shaft getting the transfare box hung up on removal..🙈😩... Tried to tidy it up but ended up replacing the shaft as the gears would no longer slide easily over the splines.. An expensive little mistake caused by trying to force it when it had jammed up.. So now I just remove the gesrs👍😁 ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17697 ![]() ![]() ![]() |
Andy, I'm not poo-pooing your method, just suggesting an alternative. It is extremely useful to use guide pins when refitting the transfer box, since these virtually eliminate misalignment problems and just leave the (rotational) spline alignment to be dealt with.
The genuine alignment stud set is (as usual) shockingly expensive at £47 +VAT from the official supplier or £73 + VAT from Dingocroft (that's a hefty mark-up!) but easy enough to make. https://www.dingocroft.co.uk/acatalog/Guid...1_009.html I find guide pins and a wiggle works for me, other may not in which case your idea is great. ![]() |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
I managed mine on my own, very easy getting it out. Getting it in was slighty more difficult but again, managed it on my own.
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I didn’t think it was possible on my own but it was okay. I’d used a local garage for clutch and box work thinking it was too much to do at home. But with a bit of time and the right (ish) tools it was okay. Dropped the transfer box off the back using an engine lift and strap through the panel below the cubby.
It was more fun getting the M57, auto box and transfer box back in one unit by myself, especially when I hit the gravel on the drive with lift. ![]() ![]() Click image to enlarge |
