Home > Puma (Tdci) > Rivet part numbers |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
You want what’s called a closed/sealed head rivet for them, eBay would be the place to look steel rivets are a lot harder to do without a decent tool. If they are to replace those screws in you panels I’d go for all aluminium there not just the head.
19th Mar 2024 10:10pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 620 |
The vehicle is built with these alloy sealed rivets with steel shanks - (standard rivet gun is fine)
You can’t get full aluminium pop rivets, the shanks need to be steel. https://www.ebay.co.uk/itm/182531559658?mk...media=COPY I think it is 14mm length for the cappings as top two pass through a coupe of layers. For filling rear holes use the shortest length available. |
20th Mar 2024 1:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20342 |
Bear in mind head designs vary a little, they aren’t just standard rivets.
I seem to remember Britpart was the OEM supplier, the head is round conical and not domed like many generic rivets. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
20th Mar 2024 10:51am |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 168 |
I’ve bought genuine LR031461 rivets for exactly the same purpose of filling some random holes in the rear bodywork.
I can’t remember what they cost but they weren’t much - ordered from Duckworth LR with free P&P. Here’s what they look like - do appear to be an aluminium head with steel pin Click image to enlarge |
20th Mar 2024 11:12am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 809 |
https://parts.jaguarlandroverclassic.com/lr031461-rivet.html 2008 2.4 110 Utility Station Wagon XS.
20th Mar 2024 1:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
People will pay nearly £1 PER RIVET !
Crikey. They should only be pennies each, there is nothing special about them. Go to a fastener specialist. |
20th Mar 2024 1:57pm |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 161 |
I see some britpart for 20pi Making my Defender great again. (Or trying to at least xD)
20th Mar 2024 6:22pm |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 209 |
But it does come individually wrapped in its own branded plastic bag . |
21st Mar 2024 1:23pm |
