Home > Puma (Tdci) > Rivet part numbers
lakes
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Rivet part numbers
I’m looking to replace the rear bracket with 6 rivets in and also rivet a couple of holes from light guard rivnuts and old badges etc.
Can anyone advise on what rivets to use in the cappings and the holes? They will be being painted over.
I have already ordered RU612253 but on double checking I believe LR031461 is correct but don’t appear to be fully aluminium.
Is full aluminium the way to go?
Who knew a rivet could be so confusing!
Post #1028664 19th Mar 2024 5:25pm
NickMc
You want what’s called a closed/sealed head rivet for them, eBay would be the place to look Thumbs Up steel rivets are a lot harder to do without a decent tool. If they are to replace those screws in you panels I’d go for all aluminium there not just the head.
Post #1028716 19th Mar 2024 10:10pm
Oldowner
The vehicle is built with these alloy sealed rivets with steel shanks - (standard rivet gun is fine)
You can’t get full aluminium pop rivets, the shanks need to be steel.
https://www.ebay.co.uk/itm/182531559658?mk...media=COPY
I think it is 14mm length for the cappings as top two pass through a coupe of layers.
For filling rear holes use the shortest length available.
Post #1028723 20th Mar 2024 1:17am
Bear in mind head designs vary a little, they aren’t just standard rivets.
I seem to remember Britpart was the OEM supplier, the head is round conical and not domed like many generic rivets. $W33T $0U7H3RN $UG4R
Post #1028741 20th Mar 2024 10:51am
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I’ve bought genuine LR031461 rivets for exactly the same purpose of filling some random holes in the rear bodywork.
I can’t remember what they cost but they weren’t much - ordered from Duckworth LR with free P&P.
Here’s what they look like - do appear to be an aluminium head with steel pin
Post #1028743 20th Mar 2024 11:12am
BrickBox
https://parts.jaguarlandroverclassic.com/lr031461-rivet.html 2008 2.4 110 Utility Station Wagon XS.
Post #1028760 20th Mar 2024 1:30pm
People will pay nearly £1 PER RIVET ! Shocked
Crikey. They should only be pennies each, there is nothing special about them. Go to a fastener specialist.
Post #1028763 20th Mar 2024 1:57pm
Waka56
Germany
I see some britpart for 20pi Razz Making my Defender great again. (Or trying to at least xD)
Post #1028799 20th Mar 2024 6:22pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
But it does come individually wrapped in its own branded plastic bag Laughing .
Post #1028853 21st Mar 2024 1:23pm
