Home > Puma (Tdci) > Defender Hinge
Naycrx
Defender Hinge
Good Evening
I noticed our driver side door hinge โ€ฆ.the bottom one โ€ฆ.. there is a bit of play in it . It looks like a pin going through it. Can this be replaced. Or do we need a new hinge ?
Thanks
Post #1027964 13th Mar 2024 7:05pm
New hinge. Thumbs Up
Best to regularity grease them externally with spray grease, though that isnโ€™t even a perfect way of lubing, but helps a lot directly into the hinge pin joints.
Regardless, they all eventually wear, but slows it down a lot. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1027966 13th Mar 2024 7:19pm
BrickBox
As above. Thankfully theyโ€™re easy and cheap enough to replace. 2008 2.4 110 Utility Station Wagon XS.
Post #1027967 13th Mar 2024 7:38pm
Naycrx
Yes just ordered one โ€ฆ.. plus Keswick green primer/paint/lacquer
Post #1027968 13th Mar 2024 7:50pm
hornet
Before fitting, you can drive out the tapered pin, cut a thread and insert the grease nipple. Alternatively, drill a hole to be able to lubricate it when the door is open (conical style greaser)
https://www.offroad-monkeys.de/produkte/la...r-defender
I just remembered that there is a very practical tool that I used last night to lubricate my joints with enthusiasm:
http://www.kruemmeloffroad.de/Kardan%20neu%20text%20I%20.jpg
Post #1027997 14th Mar 2024 7:14am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
There's a diy modification here you can do to help grease the hinges.
https://www.defender2.net/forum/post707394.html#707394
Courtesy of LRA, who was inspired by lighteningtweeds. Craig.
โ€œDon't believe everything you read on the internet.โ€ โ€• Abraham Lincoln
www.scotgrc.co.uk
Post #1028041 14th Mar 2024 4:27pm
Naycrx
Great...thanks all.....
Post #1028064 14th Mar 2024 8:14pm
I forgot about that door hinge mod - one I shall have to do that sometime.
Is there any chance one of the smallest grease nipples would fit in there in that location if a small thread was tapped?
Iโ€™m tending to think that clearance room isnโ€™t available and 2mm would need to be bigger to fit one..
So the 2mm hole alone may be best, and inject.
Iโ€™d imagine a small nipple would need say 5mm clearance and thatโ€™s very close or not quite enough space.
I have a feeling itโ€™s too close, with the door closed to do that, but would look neater than an external grease coupling visible to the exterior. No Guts, No Glory.
Post #1028191 15th Mar 2024 7:45pm
Ianh
Given you would not need to inject grease that often you could get the smallest grease nipple possible , drill the hole and tap a thread in it. Then screw a nipple in to grease then immediately after remove the grease nipple and screw in a blank stop to seal the threaded hole.
But in my view the 2mm hole left as is and a needle coupler or adapter on your grease gun would be easiest, or get that chainsaw grease gun LRA highlighted. Its not like itโ€™s going to get so hot that the grease leaks out , or wet enough for water to get in.
Post #1028200 15th Mar 2024 8:06pm
Very true, I guess the very small 2mm drilled hole would take a pressurised spray grease straw as well as the chainsaw grease applicator.
Or a needle applicator simply on standard grease gun.
I was just out of curiosity wondering if there was clearance for say an M4 or M6 straight nipple, a lot of its height would be removed by its threaded section the external nipple section height Iโ€™m not sure what that would be.
I guess something like blue tac could go in the gap to see what the gap is there available.
Seems a bit sketchy the technical drawings with the dimensions that I could see when having a quick look.
What are the smallest sizes? M6 seems common (probably a bit large) there seems to be some m4 Chinese offerings.
There is 1/8โ€ BSP, which seems around the smallest. No Guts, No Glory.
Post #1028209 15th Mar 2024 8:44pm
1/8" BSP is considerably larger than 6mm.
1/8" BSP OD is 0.383" (or 9.7mm if you're French or under 50).
Post #1028214 15th Mar 2024 9:04pm
BW - I was hoping you may see this thread - do you know what sizes are the smallest grease nipple couplings are?
The ones on the GKN UJs are quite small, the actual straight coupling that goes into the 45 degree housing.
Iโ€™d imagine they may be imperial sizing, or a combo of both possibly knowing some LR parts.
1/4unf is near m6
Probably best for simplicity to just stick with the tried and tested method LRA mentioned with the 2mm hole. No Guts, No Glory.
Post #1028218 15th Mar 2024 9:18pm
Ianh
M3 seems to be the smallest, must be a very small hole to get grease through though, however I think the thread length at circa 5mm will be too long for the thickness of the hinge plus the protruding nipple will be circa 10mm long.
Post #1028219 15th Mar 2024 9:18pm
I don't think the thread size is the problem, rather the size of the coupler part of any nipple.
Given the hassle of tapping a shallow blind hole you're much better off with a plain hole and a chainsaw greaser.
Post #1028221 15th Mar 2024 9:25pm
Yes, I think that may be the issue itโ€™s too close.
There are some hinges on the market that has an external grease point on the exterior to the lower area of the hinge pin, I seem to remember they were very expensive, I know they were posted on here at one point.
I canโ€™t remember who made them, I think it maybe from Nakatanenga or somewhere similar. No Guts, No Glory.
Post #1028222 15th Mar 2024 9:25pm
