![]() | Home > Technical > LOF Clutch Assist Spring |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2057 ![]() ![]() |
Where do you fit the grease nipple then?
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3518 ![]() ![]() ![]() |
See this: https://www.defender2.net/forum/topic22839.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thanks, I’ll get a grease nipple and try it.
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 119 ![]() ![]() ![]() |
Did mine today.. thought I’d be in the 20 camp…
Turns out.. 2.5 hours..! The reason… the spring on one side didn’t fit in the bush! So after 2 hours and the standard expletives, cut knuckles etc, I knocked out the new offending bush and lined it up on the spring. Turns out it fitted one side, not the other! Too much LOF paint! Quick scrape off, fits a dream, 2 cable ties, fitted in literally 5 minutes! Thanks LOF - quality control ![]() Take the tip.. check it all fits before dropping to your knees! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Fitted the grease nipple too
![]() _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
Quick update..
Drove her today.. first time since fitting.. OMG! The difference is night and day.. Those who ask.. PUMA 2.2.. is it worth it.. YES!!! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
