Home > Expedition & Overland > DIY Drivelodge roof |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 |
I got LRbits to fit mine. They do them day in day out.
9th Mar 2024 2:16pm |
white Landy Member Since: 03 Mar 2015 Location: Mayen Posts: 16 |
I fitted it 2 years ago. With 2 people it took a weekend. If you have the tools to cut the hole, it’s easy to do. For sure you should know what you are doing. Better measure twice to be sure. The manual which is included is ok and shows you every step. So far I am happy with the roof.
11th Mar 2024 8:29pm |
J12Engineering Member Since: 06 Jun 2020 Location: Edge of the Cotswolds Posts: 30 |
I did mine last year, took it to the Pyrenees and I'm off to the Sahara shortly. The install is pretty straight forward, if you are competent with technical elements - the instructions are minimalist... There's no turning back once that hole is cut - measure many times first before committing the saw...
I also installed a 75/25 drop down bed. Click image to enlarge |
14th Mar 2024 5:54pm |
