Home > Expedition & Overland > DIY Drivelodge roof
bpbpbp
DIY Drivelodge roof
Hi, has anyone fitted a drivelodge themselves? I can't find info online. It looks like you need to mark and cut your existing roof, and I'm keen to hear from anyone who has done it to gauge difficulty. Thanks!
Post #1027353 9th Mar 2024 2:16am
camelman
I got LRbits to fit mine. They do them day in day out.
Post #1027393 9th Mar 2024 2:16pm
white Landy
Germany 2015 Defender 110 Puma 2.2 SW Fuji White
I fitted it 2 years ago. With 2 people it took a weekend. If you have the tools to cut the hole, it’s easy to do. For sure you should know what you are doing. Better measure twice to be sure. The manual which is included is ok and shows you every step. So far I am happy with the roof.
Post #1027696 11th Mar 2024 8:29pm
J12Engineering
Drivelodge Roof
I did mine last year, took it to the Pyrenees and I'm off to the Sahara shortly. The install is pretty straight forward, if you are competent with technical elements - the instructions are minimalist... There's no turning back once that hole is cut - measure many times first before committing the saw...
I also installed a 75/25 drop down bed.
Post #1028052 14th Mar 2024 5:54pm
