Home > Maintenance & Modifications > Gwyn Lewis shock mounts front.
jst
Always nice to fit something new and functional.
Existing shock turrets rusting out on the insides closest to the iner wings. Needed replacement shocks so made sense to do both. Gwyn ones will be easier to clean at least! Simple to fit too.
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027278 8th Mar 2024 1:01pm
MK
So are those OME60037? if so, how do they compare with genuine gas charged LR shocks? Puma 110" SW
Post #1027284 8th Mar 2024 2:11pm
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
I have fitted them as well very well made and probably last forever lol
Post #1027298 8th Mar 2024 3:36pm
jst
I can check number on them. They are medium duty Std length, they are actually the 2nd set.
First ones I fitted lost an overland trip and std shocks getting very hot and failing. So upgraded to medium duty std length one shocks. 90k later they are due a change. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027310 8th Mar 2024 4:56pm
These types are so much better, I have D44 ones but they are a lot easier to clean than the top hats that gets hidden corrosion.
It’s useful to use the HD turret rings as well at the same time, much more reliable.
One of those jobs to be careful with doing though that’s for sure. TheThunder Rolls🇬🇧🇺🇸
Post #1027328 8th Mar 2024 7:29pm
Screbble
I’ve had the GL turrets fitted for years -they are Superbulous.
Also fitted the HD turret rings and spring isolators at the same time.
Only wish I’d had the funds to fit Fox shocked at the time 🤪
Looks so much better and definitely makes it easier for maintenance and cleaning.
Post #1027454 10th Mar 2024 8:33am
jst
Confirmed ome60037 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027620 11th Mar 2024 2:43pm
jst
Fitted these at same time, def worth doing
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027621 11th Mar 2024 2:44pm
