Home > Maintenance & Modifications > Webasto diagnostics wire for a thermotop 12v switched?
Matt110
Hi, I have an ex-rover 75 12v switched thermotop C which has stopped functioning and needs a reset and a code read so I know what to change to repair it.
I know Martin used to sell wires for connecting and reading the units.
Have this link....
https://www.disco3.co.uk/wiki/Fuel_Burning...t_Software
But I'm not sure this works with my 1 pink diagnostic wire? And I don't think the link to the shop works any more?
Could I ask for your help please any webasto gurus out there.[/quote][/b]
Post #1027048 6th Mar 2024 9:39pm
jst
was it in your vehicle working?
flashing lights or display read out if it has one? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027248 8th Mar 2024 7:04am
Martin
Site Admin
You can diagnose the TTC with the WTT software, yes.
There’s a menu option to pick the TTC, I have done it with BMW/L322 heaters.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027254 8th Mar 2024 9:00am
Martin
Site Admin
Pin 2 is diagnostic/comms line, is that wired in?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027255 8th Mar 2024 9:01am
Matt110
Thanks. Sorry for really delayed reply.
Yep (pink?) pin2 diagnostics wired in and I left it out of the loom to be able to access it.
Curiously however.....
I reset it properly today by turning the power off whilst it was switched on.
On restart, it fired up normally, got into "normal" operation with fan at full speed and fuel pump ticking at normal operation speed, then shut down and dumped a massive cloud of white smoke out the exhaust. Which I assume to be a symptom of the fast shut down rather than the actual error state in operation.
Are there any common faults they develop that cause.... I guess... An over heat and shut down or something else similar?
Post #1029098 23rd Mar 2024 7:01pm
Matt110
Sorry. Quick bump in case anyone can offer any guidance
Thanks.
Post #1030146 1st Apr 2024 10:34pm
