Home > Technical > Dynaliner
chazza
 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Dynaliner
Morning,
I’m about to venture down the soundproofing rabbit hole….
I’ve got dynamat for the doors and door cards.
I’ve also got some dynaliner, is it best to use on top of the dynamat on the door skin or on the inside of the actual door card?
Many thanks.
Post #1026106 27th Feb 2024 8:09am
On top of the dynamat on the door, but you’ll need to make sure you can keep the door card sitting flush around the door handles. (A bit of dynamat on a lower section of the door card might be worthwhile).
It’s not too much involved with that, Some brake cleaner in a well ventilated place and brand new microfibre cloths are ideal for pre clean up. Or you can use rubbing alcohol, obviously beware of making sure there is no source of ignition during that proces…
While you are in there, it’d pay to clean and relube with a little silicone grease the door mechanisms and electric window mechanisms.
Basically any mechanical items in the doors if you have them, once the dynamat job is done.
Makes the central locking system work much better and smoother, and the electric windows as well.
Much better once done, and an ideal time to do it, it only needs doing once in a blue moon like the windscreen wiper wheel box and rack greasing so is well worth doing.
I was surprised how nicely it all worked, much smoother and that is useful with the Dynamat as well every little helps. WeWillWin🇬🇧🇺🇸
Post #1026125 27th Feb 2024 11:42am
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
For those who have put dynaliner in - what thickness did you use? Obviously want to get the thickest possible in there without it becoming impossible to get the doorcard back on.
Post #1056542 7th Jan 2025 12:03pm
mptzs90
I got a couple of pieces of 6mm in against the outer door skin, definitely not full coverage since the window needs space at the bottom and then a 6mm piece stuck to the back of the door card. Also dynamat extreme where i could get it on the outer and inner skin and a bit on the door card… mostly to add weight because i don’t think it’ll do anything else there
Post #1057701 17th Jan 2025 9:44pm
