![]() | Home > Technical > Dynaliner |
chazza Member Since: 02 Dec 2010 Location: Channel Islands Posts: 11 ![]() ![]() ![]() |
Morning,
I’m about to venture down the soundproofing rabbit hole…. I’ve got dynamat for the doors and door cards. I’ve also got some dynaliner, is it best to use on top of the dynamat on the door skin or on the inside of the actual door card? Many thanks. |
mptzs90 Member Since: 24 May 2024 Location: Kent Posts: 66 ![]() ![]() ![]() |
For those who have put dynaliner in - what thickness did you use? Obviously want to get the thickest possible in there without it becoming impossible to get the doorcard back on.
I got a couple of pieces of 6mm in against the outer door skin, definitely not full coverage since the window needs space at the bottom and then a 6mm piece stuck to the back of the door card. Also dynamat extreme where i could get it on the outer and inner skin and a bit on the door card… mostly to add weight because i don’t think it’ll do anything else there
