Home > Puma (Tdci) > Puma 2.2 water temperature sensors.
Stephen W
United Kingdom 2014 Defender 110 Puma 2.2 CSW Sumatra Black
I have a 2.2 Puma with overheating issues so was going to change the temp. sensors before I start changing anything else. I purchased a cylinder head temp. sensor which is listed as being for the 2.2 and 2.4 but I can't find the existing one at the back of the cylinder head; where it is supposed to be. Can anyone confirm that the 2.2 does actually have a cylinder head sensor? I do have a water temp. sensor on the top radiator hose.
Post #1025880 24th Feb 2024 11:59pm
Daphne
United Kingdom 2015 Defender 110 Puma 2.2 HCPU Fuji White
The temp on the 2.2 is read from the sensor on the right hand hose leaving rad there isn’t a cylinder head sensor there is also an oil temp sensor on right hand side of engine on opposite side of oil cooler.
Post #1025882 25th Feb 2024 12:11am
Stephen W
Thanks Daphne, I'll order the hose sensor.
Post #1025886 25th Feb 2024 12:39am
Daphne
What mileage on it may be worth ordering a new thermostat also, simple job.
Post #1025905 25th Feb 2024 9:54am
Stephen W
I've already got the thermostat, was going to replace with the sensor. Done 106K but engine replaced (by a previous owner) at 90K. I have an ongoing overheating issue that I hope isn't the head gasket.
Post #1025919 25th Feb 2024 2:34pm
