Home > Puma (Tdci) > Puma 2.2 water temperature sensors. |
Stephen W Member Since: 20 Feb 2024 Location: Cheltenham Posts: 5 |
I have a 2.2 Puma with overheating issues so was going to change the temp. sensors before I start changing anything else. I purchased a cylinder head temp. sensor which is listed as being for the 2.2 and 2.4 but I can't find the existing one at the back of the cylinder head; where it is supposed to be. Can anyone confirm that the 2.2 does actually have a cylinder head sensor? I do have a water temp. sensor on the top radiator hose.
24th Feb 2024 10:59pm |
Daphne Member Since: 22 Nov 2023 Location: Kent Posts: 25 |
The temp on the 2.2 is read from the sensor on the right hand hose leaving rad there isn’t a cylinder head sensor there is also an oil temp sensor on right hand side of engine on opposite side of oil cooler.
24th Feb 2024 11:11pm |
Thanks Daphne, I'll order the hose sensor.
24th Feb 2024 11:39pm |
What mileage on it may be worth ordering a new thermostat also, simple job.
25th Feb 2024 8:54am |
I've already got the thermostat, was going to replace with the sensor. Done 106K but engine replaced (by a previous owner) at 90K. I have an ongoing overheating issue that I hope isn't the head gasket.
25th Feb 2024 1:34pm |
