Home > General & Technical (L663) > Snow Chains and Differential
steam_simon
I'm off to the Alps next week. I have LR snow chains but not sure if they should go on the rear or front? I think it's rear...
Also, how can I lock the differential manually (that's standard one between the rear and front wheels that shows on the 4WD digital display with a padlock icon)?
Post #1025802 24th Feb 2024 11:09am
The Phantom Menace
Belgium
Don't know the answer to your 2nd question, but I do know you have to put the snow chains at the 2 front wheels. Good luck and have fun at the Alpes! Spec: Land Rover New Defender 110 X-Dynamic SE - P400
Post #1025829 24th Feb 2024 4:12pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I think you can only manually lock the centre dif if you selected the configurable terrain response, which is part of the advanced off-road pack when you purchased the car or you have had it enabled by the Gap IID tool etc.
If they are the genuine Land Rover snow chains Land Rover says to fit them on the rear axle as per the instructions - https://accessories-instructions.landrover...r/G2417292 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1025838 24th Feb 2024 5:09pm
snowtiger
Germany
NEVER, NEVER on the front wheels on a 4x4. Always on the rear. If you loose traction on the front, it is not too bad. If your rear tries to overtake you, good luck...
Post #1025848 24th Feb 2024 6:13pm
Unless you fit four chains.
Post #1025885 25th Feb 2024 12:29am
Nuclear Nick
iGuide says only fit chains to rear wheels.
I guess in extreme conditions chains might help on all four wheels but then there’s the risk of damage due to rubbing especially with standard width wheels.
Post #1025900 25th Feb 2024 9:30am
snowtiger wrote:
... NEVER, NEVER on the front wheels on a 4x4...
I was responding to the comment quoted above which makes no reference to Defenders.
Follow JLR's advice for the new Defender, there is no reason not to use chains on the front of a classic Defender or Series.
Post #1025904 25th Feb 2024 9:51am
steam_simon
Thanks for all your advice!
Post #1025993 26th Feb 2024 11:17am
XplusYplusZ
Looks like the LR guidance is REAR wheels:
Post #1026013 26th Feb 2024 1:59pm
The Phantom Menace
Belgium
Sorry for the bad advice then. It must be a mistake in the Land Rover configurator. The red part reads in Dutch "Recommended for use on the front wheels only."
But the information from the IGuide claims the opposite. I second your advice about the installation on the rear wheels.
Post #1026889 4th Mar 2024 11:50pm
