Home > Td5 > 2003 TD5 - stall and loss of power
roche1800
We have a 2003 td5 90, typically it seems to stall at traffic lights and then when it starts there is a loss of power for approx 30 seconds and then it kicks back in and works ok. This is an intermittent issue and has happened twice!
Post #1025158 19th Feb 2024 11:26am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, when you go to restart do you hear the fuel pump buzzing or any gurgling like air is being expelled from the system? Any oil in the injector harness where it meets the ECU under the driver's seat?
Post #1025159 19th Feb 2024 11:38am
landy andy
Try driving it with the MAF disconnected.
Post #1025181 19th Feb 2024 2:11pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
What is your fuel level like when this happens? 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1025212 19th Feb 2024 6:42pm
htb2
Wales
Mine does it quite often after a stall, or after a quick start and drive off, done it for over130K miles, thought it was normal but irritating. Be interested if there is a solution. MAF been disconnected for years.
Post #1025217 19th Feb 2024 7:36pm
