![]() | Home > Td5 > 2003 TD5 - stall and loss of power |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 334 ![]() ![]() ![]() |
Hi, when you go to restart do you hear the fuel pump buzzing or any gurgling like air is being expelled from the system? Any oil in the injector harness where it meets the ECU under the driver's seat?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5833 ![]() ![]() |
Try driving it with the MAF disconnected.
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 225 ![]() ![]() ![]() |
What is your fuel level like when this happens? 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 542 ![]() ![]() |
Mine does it quite often after a stall, or after a quick start and drive off, done it for over130K miles, thought it was normal but irritating. Be interested if there is a solution. MAF been disconnected for years.
