Home > Maintenance & Modifications > rock sliders
Page 2 of 3 <123>
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
sliders
im after the ones to use as a step as well just like your photos.
Post #99409 11th Nov 2011 8:22pm
fekete
fekete wrote:
I've got these very well made Thumbs Up
http://www.ebay.co.uk/itm/Rock-Sliders-Lan...197wt_1185
You can see here the difference how thick these are to most out there...Also how good the weld and finish is Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99415 11th Nov 2011 8:41pm
tolley
sliders
Post #99419 11th Nov 2011 8:45pm
fekete
They look ok but no speck on the thickness in steel ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99420 11th Nov 2011 8:47pm
Green Machine
Really like the look of those! Are they galv underneath? Or just powder coated? Very tempted . . .
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2005 Td5 | 90 Station Wagon | Tonga Green
Post #99421 11th Nov 2011 8:54pm
fekete
Just powder coated....I'd wish i just got them bear and got them galved and powder coated myself...the finish is great and when they peel if they do or i knock them then i can get them done for free anyway Very Happy
but well worth the money Thumbs Up
Had them on now for a good 8 mouths with know sign off any peeling or rust showing through...also been off roading a few times in them NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99424 11th Nov 2011 9:01pm
leeds
Tolley there is a wide range of suppliers out there and a wide range of prices
Personally I would not touch underbody or side body protection which has not been galvanised. We use our vehicles as they were meant to be used. This means that the protection gear is used as it is meant to be used and takes knocks and bumps. Any decorative finish is damaged. That is when having them galvanised pays off. If you want them just for looks then buy on price alone.
If you are going to use the tree slider as a step get some anti slip tape and fixed it to the top. Don't take it around the outside surface, as that can prove painful if you wear shorts. Razz
Brendan
Post #99429 11th Nov 2011 9:10pm
fekete
Well said Brendan...I got a nass step and got it blasted and galved...the best thing i ever done as today i reversed
into a lamppost Rolling Eyes the first thing i thought was Censored i've wrecked the lights and back end.... good for me the step took the brunt and only the powder came off... i can sleep with that as i know its not going to rust....so as you say if you can get any product for protection galved do it Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99431 11th Nov 2011 9:27pm
leeds
Well the bumpers on our Disco are rusting as we have scrapped them on the odd dry stone wall etc.
The chances are they will be coming off in the next few months, get stripped, galvanised and then powder coated.
Brendan
PS Please remember powder coating sticks better to plain metal then galv
Post #99438 11th Nov 2011 9:50pm
JSG
I had galv ones on the 90, quality of fit and welds etc was spot on but they black powder coating came away if you looked at them. John
2011 Tdci 110 CSW XS
Post #99475 12th Nov 2011 9:41am
It would probably be better to prime and paint galvanised ones. That way, they could easily be touched up when inevitably scratched. Darren
Post #99478 12th Nov 2011 9:46am
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
ask you powder coater to acid prime first, the bumper i make can be hit with a hammer and the powder coat won't budge, also make sure they are cured right.
a lot of p coaters only melt the paint and don't leave in the oven long enough to cure it.
a 110 rock slider out of 2.5- 3mm awl steel and 2mm walled tube(tree sliders) should take 1 hour 25 mins on average, dependant on powder finish and make.
Post #99479 12th Nov 2011 9:54am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Got mine from safari equi real heavy duty but if you get galvanised ones ask them to get them powder coated at pm coatings Elland as the other coaters these use are crap but if you just go for powder coat they get them done there anyway Thumbs Up
Post #99530 12th Nov 2011 7:22pm
Tim_NZ
Australia
I ended up going the DIY route:
I used 50x100 box section, with 50mm tube, and 10x10 square steel as a filler on top of the box section to close up the gap between the sliders and the doors.
Cheers,
Tim
Post #100526 17th Nov 2011 2:17pm
T1G UP
got a set of 90 sliders without the tree bars here? galved, will need painting or powder coating etc
Post #100530 17th Nov 2011 2:29pm
Page 2 of 3 <123>
