Home > Td5 > 110 TD5 SW replacement springs
GowerDriver
United Kingdom 2006 Defender 110 Td5 CSW Keswick Green
Hi,
I need to replace the dampers on my 110 TD5 station wagon as it has now done 130K and they are leaking. It is like driving a Spacehooper! Neutral
I'm thinking of going for the Bilstein B6.
I do mostly road miles as daily driver and longer trips to Scotland and France. I do a bit of off road and I also tow a 2.5T trailer reasonably frequently.
Looking at the springs they are rusted and I may as well change those at the same time and this is where I have become increasingly confused.
I have been trawling through he message boards and found a couple of useful tables which seem to recommend Yellow/Yellow ( NRC 8045) on the front and Green/green/white (RKB500300) for the back.
However when I look on sites to order they state -except station wagon for these springs.
It seems from my reading that suspension set ups are very variable and personal choice.
Does anyone have any recommendations, dos and don'ts? I don't want to be stuck with he wrong set up.
Thanks in advance
Post #1024824 15th Feb 2024 9:30pm
TexasRover
The station wagon I believe has softer rear springs, but the difference is not a lot. You can go for progressive springs but might find the rear will right a bit higher.
If it is 'comfort' you are after I would go for the stock station wagon springs
Post #1024837 16th Feb 2024 5:15am
kenzle8a
I would be tempted to look at Alives Custom Bilstein Advanced dampers over the plain B6. I had B6's on mine and they are pretty old in terms of set up now.
Post #1024849 16th Feb 2024 9:02am
4RF RDS
I recently replaced mine with genuine OE Land Rover coils and shocks. Land Rover actually knows what they are doing with their suspension set ups. I highly recommend using OE or genuine. I mean mine lasted 150,000Kms. I doubt any aftermarket system would do thatβ€¦πŸ€·β€β™‚οΈ
Some comparative info on both πŸ‘‡πŸ»
http://www.red90.ca/rovers/springinfo.html
http://www.red90.ca/rovers/shockinfo.html
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1024918 16th Feb 2024 4:58pm
GowerDriver
Thanks for the advice. I will probably go for the LR springs and look at the Alive tuning dampers as you advised. β€œThe fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.”
― Bertrand Russell
Post #1025284 20th Feb 2024 9:46am
Castillo
Finland
I fit few weeks ago NRC 8044/8045 to the front and RKB500300 rear... I'm really happy with this setup. I have koni heavy track with them . I have had also terrafirma +2" suspension one year (not good) and h&r -40mm springs couple of years few year ago (too hard). But. This new setup is the best I know in my opinion. Fantastic and
comfortable riding πŸ‘Œ defender 110 td5 2006
Post #1025332 20th Feb 2024 3:38pm
GowerDriver
Thanks great photo β€œThe fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.”
― Bertrand Russell
Post #1026057 26th Feb 2024 6:42pm
Linds Hanson
I would recommend standard Genuine SW springs with Fox dampers they give a much more compliant ride qaulity than any of the Bilstein offerings.
Post #1026124 27th Feb 2024 10:39am
GowerDriver
Thumbs Up β€œThe fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.”
― Bertrand Russell
Post #1026564 2nd Mar 2024 10:40am
