Home > Td5 > Bridged socket - What and why?
Craig772
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Hi all,
I am digging around behind the dash instrument panel and have found this socket that is bridged. Does anyone know what the socket is for and why it would be bridged? Presumably it's for an option I have don't have on my 2000 TD5 90 CSW.
TIA.
 https://www.instagram.com/roxi_defender90/
Post #1023448 3rd Feb 2024 2:39pm
Martin
Site Admin
Dim dip unit has been removed and the socket bridged to maintain normal headlamp function.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1023449 3rd Feb 2024 2:48pm
Craig772
Thanks @Martin. A quick Google of 'Defender Dim Dip' threw up a couple of discussion threads.
Apparently the Dim Dip relay passes a lower voltage to the dipped headlight connection when the side lights are on and the oil pressure switch is open. The oil pressure switch is used as an indication that the engine is running, so you can have just the side lights on when parked.
Having a dim-dip system in your car was a regulation that came about in the 80s in the UK, but is no longer necessary. The feature was fitted right into the Puma model.
Seems there's a bypass relay available - YWZ10003L but the bridge works just as well.
Thanks. https://www.instagram.com/roxi_defender90/
Post #1023452 3rd Feb 2024 3:04pm
PaulMc
There is a Genuine bypass unit to replace the dim-dip relay - YWZ10003L
But, it costs around £35 Shocked
https://rimmerbros.com/Item--i-YWZ10003L
. Paul.
Post #1023453 3rd Feb 2024 3:13pm
Craig772
Hmmm £35 or leave the bridge in... Shocked https://www.instagram.com/roxi_defender90/
Post #1023455 3rd Feb 2024 3:28pm
If you pop the lid off the official bypass unit all you will find is a short length of wire linking the two spades together.
In effect you're paying £35 for a plastic cover.
An even simpler solution is to unplug the dim-dip resistor, although this means that the DD relay is still required. If the relay fails, bridge the terminals as in the OP's picture.
Post #1023457 3rd Feb 2024 3:43pm
Craig772
I think I'll leave the bridge in but make it a bit more robust with some tape. https://www.instagram.com/roxi_defender90/
Post #1023492 3rd Feb 2024 8:10pm
