![]() | Home > Td5 > Bridged socket - What and why? |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 73 ![]() ![]() ![]() |
Hi all,
I am digging around behind the dash instrument panel and have found this socket that is bridged. Does anyone know what the socket is for and why it would be bridged? Presumably it's for an option I have don't have on my 2000 TD5 90 CSW. TIA. ![]() Click image to enlarge https://www.instagram.com/roxi_defender90/ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6647 ![]() ![]() ![]() |
Dim dip unit has been removed and the socket bridged to maintain normal headlamp function.
Thanks @Martin. A quick Google of 'Defender Dim Dip' threw up a couple of discussion threads.
Apparently the Dim Dip relay passes a lower voltage to the dipped headlight connection when the side lights are on and the oil pressure switch is open. The oil pressure switch is used as an indication that the engine is running, so you can have just the side lights on when parked. Having a dim-dip system in your car was a regulation that came about in the 80s in the UK, but is no longer necessary. The feature was fitted right into the Puma model. Seems there's a bypass relay available - YWZ10003L but the bridge works just as well. Thanks. https://www.instagram.com/roxi_defender90/ |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
There is a Genuine bypass unit to replace the dim-dip relay - YWZ10003L
![]() Click image to enlarge But, it costs around £35 ![]() https://rimmerbros.com/Item--i-YWZ10003L . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Hmmm £35 or leave the bridge in...
I think I'll leave the bridge in but make it a bit more robust with some tape. https://www.instagram.com/roxi_defender90/
