Home > Td5 > NNN 10p maps |
Spark1 Member Since: 16 Sep 2024 Location: SoCal Posts: 3 |
Greetings!
I have a '99 D90 td5. After troubleshooting a "kangarooing" issue I discovered the MSB ECU was from a disco. I sourced an NNN5000250 ECU Said to have been removed from a D90 manual and Nanocom evolution for TD5's. Received the new ECU first and decided to try it. Truck started with immediate "check engine" amber light and would only idle...no response from accelerator pedal. After receiving the Nanocom and creating map sttlp009-sthle022 file using the map wizard. I flashed the map and unfortunately have the same results as without the map only now I have the fault codes: NANOCOM - TD5ENG.APP - TD5 ENGINE fault file (8,1) AIR CONDITIONING FAN DRIVE OVER TEMPERATURE, (LOGGED). --- (8,2) FUEL PUMP DRIVE OVER TEMPERATURE, (LOGGED). --- (8,3) TACHO DRIVE OVER TEMPERATURE, (LOGGED). --- (8,4) GEARBOX/ABS OUTPUT DRIVE OVER TEMPERATURE, (LOGGED). --- (8,5) AIR CONDITIONING CLUTCH DRIVE OVER TEMPERATURE, (LOGGED). --- (8,6) MIL LAMP DRIVE OVER TEMPERATURE, (LOGGED). --- (8,7) GLOWPLUG RELAY DRIVE OVER TEMPERATURE, (LOGGED). --- (8, GLOWPLUG LAMP DRIVE OVER TEMPERATURE, (LOGGED). --- (10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED). --- (10,2) FUEL PUMP DRIVE OPEN LOAD, (LOGGED). --- (10,3) TACHOMETER DRIVE OPEN LOAD, (CURRENT). --- (10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED). --- (10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED). --- (10,6) MIL LAMP DRIVE OPEN LOAD, (LOGGED). --- (10,7) GLOWPLUG LAMP DRIVE OPEN LOAD, (LOGGED). --- (10, GLOWPLUG RELAY DRIVE OPEN LOAD, (LOGGED). --- (12,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT). --- (12,2) FUEL PUMP DRIVE OPEN LOAD, (CURRENT). --- (12,3) TACHOMETER DRIVE OPEN LOAD.(CURRENT). --- (12,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). --- (12,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). --- (12,6) MIL LAMP DRIVE OPEN LOAD, (CURRENT). --- (12,7) GLOWPLUG LAMP DRIVE OPEN LOAD, (CURRENT). --- (12, GLOWPLUG RELAY DRIVE OPEN LOAD, (CURRENT). --- (14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT). --- (14,2) FUEL PUMP DRIVE OPEN LOAD, (CURRENT). --- (14,3) TACHOMETER DRIVE OPEN LOAD, (CURRENT). --- (14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). --- (14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). --- (14,6) MIL LAMP DRIVE OPEN LOAD, (CURRENT). --- (14,7) GLOWPLUG LAMP DRIVE OPEN LOAD, (CURRENT). --- (14, GLOWPLUG RELAY DRIVE OPEN LOAD, (CURRENT). --- (21,6) PROBLEMS DETECTED WITH DRIVER DEMAND (LOGGED). --- (25,6) PROBLEMS DETECTED WITH DRIVER DEMAND (CURRENT). I have read that map sttlp009-sthle022 is correct for a 10p but it is unclear on the map wizard. I am assuming I have the wrong map or reflash to see. Any suggestions? |
16th Sep 2024 4:49pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 632 |
First you have to set the gas pedal - you have probably two way, and in ECU is three way. Than clean faults and it should response and not only idle. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
17th Sep 2024 6:46am |
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 |
There is no specific mapset for running a Defender on a NNN500250 ECU, as it was only fitted to 15p Discos. Much less so a 10p Defender.
The sttlp009-sthle022 mapset is for the NNN00120 ECU. You'd be better off trying with a sttlp010-sthle022 mapset, originally intended for the NNN500020 ECU, which in terms of hardware is a much closer relative to the NNN500250. Then confirm/change the accelerator setting to 2-way (Nanocom --> Td5 Engine --> Settings --> Injectors - Throttle --> 2nd page/tab 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
17th Sep 2024 6:47am |
Thank you! Will try that |
22nd Sep 2024 6:09pm |
I flashed the sttlp010-sthle022 map and changed throttle to two way as suggested and it worked like a charm. Thank you! I should be getting the corrected version to account for 10p engine tomorrow but she runs so much better than with the old disco ECU
22nd Sep 2024 9:07pm |
