Home > Td5 > Webasto thermo top c
chinnus
2001 Defender 90 Td5 ST Coniston Green
Evening all, I’m about to install a thermo top c into the defender !
I wonder if anyone has solved the problems below…
When splicing in the relay to operate the heater fan can you use my aux battery rather than the main engine battery? Has anyone done this?
What happens if you turn on the main heater controls fan whilst the webasto is powering the heater fan ? Presumably this would end badly?
Do people have the fan operate from cold or does it kick in the relay once the webasto has reached operating temperature ?
I hope this is clear ! Thanks in advance for the comments
Post #1021229 14th Jan 2024 9:53pm
4RF RDS
Do you have the Td5 install manual from Webasto? It has all this info in it? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1021406 16th Jan 2024 2:31pm
chinnus
I do have that, I couldnt work it out …. I will have a look again!
Thanks
Post #1021407 16th Jan 2024 2:35pm
4RF RDS
1967 MGB GT
Post #1021411 16th Jan 2024 3:25pm
chinnus
Thank you
Post #1021424 16th Jan 2024 5:46pm
