![]() | Home > Td5 > Webasto thermo top c |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
Evening all, I’m about to install a thermo top c into the defender !
I wonder if anyone has solved the problems below… When splicing in the relay to operate the heater fan can you use my aux battery rather than the main engine battery? Has anyone done this? What happens if you turn on the main heater controls fan whilst the webasto is powering the heater fan ? Presumably this would end badly? Do people have the fan operate from cold or does it kick in the relay once the webasto has reached operating temperature ? I hope this is clear ! Thanks in advance for the comments |
I do have that, I couldnt work it out …. I will have a look again!
Thanks |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thank you
