![]() | Home > Modifications & Maintenance (L663) > 110 cup holder delete possible? |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 276 ![]() ![]() |
There is a torx screw on the inside of the cup holder. Make sure you get the right size as they are different vs. the interior side door panel. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san" |
waldoverkill Member Since: 11 Mar 2021 Location: Auckland Posts: 10 ![]() ![]() |
You do have to get a little brutal on them to get them out.
bigfootcal Member Since: 04 Jan 2024 Location: Oxfordshire Posts: 8 ![]() ![]() |
Thank you for the help
snowtiger Member Since: 06 Oct 2022 Location: Bavaria Posts: 33 ![]() ![]() |
The torx screw is not the only thing holding the cupholders in place. There are 3 plastic rivets "soldered" to the panel. Best way to remove is from the back and put in some rubber plugs in the now open holes.
![]() Click image to enlarge The torx screw is not the only thing holding the cupholders in place. There are 4 plastic rivets "soldered" to the panel. Best way to remove is from the back and put in some rubber plugs in the now open holes. |
