Home > Modifications & Maintenance (L663) > 110 cup holder delete possible?
bigfootcal
Hello,
I have a 110 with the 7 seats in it. Im fed up of the cup holders at the side protruding into the load space in the 3rd row. Anyone know if they can be removed or alternative panels are available?
Thanks in advance for the advice
Post #1020771 10th Jan 2024 10:10pm
haymeister
Japan
There is a torx screw on the inside of the cup holder. Make sure you get the right size as they are different vs. the interior side door panel. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1021357 16th Jan 2024 1:05am
waldoverkill
New Zealand
You do have to get a little brutal on them to get them out.
Post #1021361 16th Jan 2024 2:18am
bigfootcal
Thank you for the help
Post #1021455 16th Jan 2024 10:00pm
snowtiger
Germany
The torx screw is not the only thing holding the cupholders in place. There are 3 plastic rivets "soldered" to the panel. Best way to remove is from the back and put in some rubber plugs in the now open holes.
Post #1024261 10th Feb 2024 10:43pm
snowtiger
Germany
The torx screw is not the only thing holding the cupholders in place. There are 4
Post #1024262 10th Feb 2024 10:48pm
