![]() | Home > In Car Electronics > L663 centre console fridge. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6643 ![]() ![]() ![]() |
Do you have a photo?
BJolly Member Since: 08 Jan 2024 Location: Canterbury Posts: 5 ![]() ![]() |
It’s the socket that connects into this one. Two pin.
It's got 2 wires fitted, but is it just a 2 way connector or are there unused ways?
Any face-on view of it, and of the connector on the loom if possible? It's not the shape I'm expecting for a 2 way connector, that's all! ![]() ![]() |
I've had a look online, and can only find a Chinese pattern fridge, and that appears to use the same connector as the D3/D4/RRS1 fridge, which I have in stock:
https://fnltd.co.uk/shop/2-pin-plug-for-de...-p126.html ![]() Click image to enlarge This wouldn't fit the socket in your photo though, I think the one in the photo is more like an 8 way housing ![]() ![]() Click image to enlarge ![]() ![]() |
I've tracked down the socket in your photo (I believe it is 8 way), I can provide a matching plug and terminals if required.
Thanks all for the help
