Home > Td5 > Transfer conversion Vs Overdrive
Page 2 of 2 <12
TJ101
I have had both,, and still have a TD5 90 for the lanes etc with a GKN fitted
With hindsight, would always go the overdrive route if possible,, trouble is, as far as i know, you can no longer get them,, Ashcrofts did do them,
From memory last price was getting on for £1500, so the gear set up is a lot cheaper, even secondhand, if you can find one, they still make £500-£700
Still try and go for 6th gear all the time, plus good to drive every now and again, to appreciate how much more refined the Puma is Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #99206 10th Nov 2011 7:55pm
jst
GKN and Roverdrive i thought were the only two OD suppliers.
Ashcrofts do UD, didn't know they did an OD too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #99219 10th Nov 2011 8:32pm
TRR Motorsport
United Kingdom 2010 Defender 90 Puma 2.4 ST Galway Green
From personal experience I've had both on my 110. the GKN overdrive had all the benefits you'd expect, no change to 1st ratio, higher MPG, quieter and less tiring at speed.
On the downside I lunched two of them, both just outside the warrenty! It turned out that the GKN overdrive unit is based on a Laycock unit used in a Triumph. It wasn't designed to take high tourque/high loads and would be prone to overheating.
A fat lot of use when fully laden with service gear and a Rally car being trailered behind us then!
Now I run the Ashcroft Disco transfer gears. It isn't as nice towing (1st is too high and you can't down shift as quick without the overdrive when losing speed up steep hills.)
In all honesty. it needs a remap. I've been saying that since i fitted the disco gears, maybe one day I'll get round to it. "If it ain't sideways, you just ain't tryin'!
Post #103775 1st Dec 2011 1:24pm
Page 2 of 2 <12
