Home > Technical > HELP! Cam/Timing belt has been chewing itself up….
Dick
United Kingdom 1994 Defender 90 200 Tdi HT Shire Blue
I’m pretty OCD, and realised as I was about to head on a few weeks of driving up and down the country over Christmas that a pretty crucial service item had been missed off my list.
So obviously decided to change the cam belt the day before.
And I’m glad I did.
After getting the cover off the front the space with the gears was full of burnt up rubber, and it’s clear the cam belt has been rubbing away against the case, or something.
My questions are:
- Is this common for an old cam belt if it’s got slack
- should I be looking for anything else while I’m in there
- is this a common occurance for another reason
Any help really really appreciated.
Thanks
Post #1018808 20th Dec 2023 11:21am
Dick
Worth mentioning - 1994
200tdi
Post #1018812 20th Dec 2023 11:32am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
It can even happen to the new pulley setup.
Happened to me a year ago, it was just a small piece of dirt behind the tensioner pulley.
When I installed the belt a few years ago I did see that the belt wandered around but I thought it would settle.
Now I make sure that it's spotless behind the pulleys and check for a wandering belt.
Post #1018821 20th Dec 2023 1:13pm
Dick
Glad it’s not just me
Everything will be spotless before getting reassembled and anything replaceable will be replaced!
Fingers crossed!
Funny because I always thought I could smell burning rubber!
Post #1018824 20th Dec 2023 1:59pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
There was a problem with the 300tdi belt alignment which required a rectification kit from Land Rover, but looks like yours is a 200tdi?
Just replace idler and tensioner with quality parts (definitely not a place for anything in a blue box!) and follow the install procedure to the letter.
Post #1018840 20th Dec 2023 5:22pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
On the 300, there was a revision to swap the lip from the idler to the crank sprocket.
I don't know if the same was implamented on the 200, but your photos certainly show the lip on the idler rather than the sprocket.
If you buy a belt kit, are there different options? (The 300 has a more expensive kit which has the crank sprocket in it also, for engines that have not been revised - im thinking just looking at the costing of the 200 kits may be an easy way to tell?)
Post #1018861 20th Dec 2023 9:23pm
Retroanaconda
Any play in the idler bearing? Even a small amount can cause this - has happened to me.
Post #1018862 20th Dec 2023 9:25pm
Dinnu
Is that a plastic idler? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1018880 21st Dec 2023 7:16am
julian
I just had a very brief look about...
The idler in the photo looks like ERR2530
..however, ETC 8560 seems to be listed for both the 300 and 200, which would imply there IS the option on the 200 to move the lip "somewhere else" (assume the crank sprocket but I've not checked) as per the 300tdi revision.
...that was implamented to stop belt wander.
Post #1018883 21st Dec 2023 8:09am
sako243
On the 300s the crank pulley has a lip around it to stop the wander.
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1018944 21st Dec 2023 6:20pm
NickMc
I had this problem a few years ago (don’t do many now) Aftermarket! so bought it all from the dealer, wasn’t that much of a difference in price. Make sure everything is clean and seated right and the crack bolt is tight. I remember something about a spot welded ring/lip in particular
Post #1018967 21st Dec 2023 9:32pm
mini Anaconda
Just resurrecting this thread as I have noticed some rubber "fluff" coming out of the hole in the timing case where the wading plug goes, so I assume my timing belt is wearing itself down as the photos in this thread show.
The timing belt was replaced approx 500 miles ago with a Dayco belt and OEM tensioner and idler. It was all clean when it was put back together.
What is the resolution to this as if I change the belt, tensioner and idler again, what is to stop it from happening again?
Engine is a Discovery 200tdi in my 90.
 BORG - Bucks & Oxon 4x4 Response Group
Post #1061745 2nd Mar 2025 4:49pm
sako243
You need to find out why it's wandering (something not aligned properly) unless it wasn't done properly when it was replaced.
I have had a tensioner work loose that I'd installed but I'd had a pig of a time getting the bolt in so wonder if the threadlock had started to go off. After a couple of thousand miles it had released enough tension to jump a tooth and then another which bent some push rods. Ed
Post #1061749 2nd Mar 2025 4:58pm
jfh
Mine was a little bit of dirt behind the tensioner pulley, that was all it took.
Post #1061754 2nd Mar 2025 5:17pm
