![]() | Home > Maintenance & Modifications > Bonnet swap?? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
As far as i know it should be a straight swap
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
I was sort of hoping that it would be.
I have been thinking of it for quite a while now, then saw a TD5 on Foley's site with the new Puma bonnet, so I assumed it could be done fairly easily. My friend has just picked up a de-cat downpipe and mid-pipe replacement, so they will be going on when I next change the oil. I will probably get around to looking at the bonnet after that. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
it can be done no changes i can see
Oh an i love its look Mike |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
I sent the lynch mob back to the bar as that is a good reason. ![]() As for the other annoying Defender Water Feature...dammed (and damned) water cascading from the roof over the windscreen....may be a bulge (or a bilge pump) in the roof would fix that too ![]() '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Oh you mean it's not just mine that do that ![]() As for the bonnet I've been tempted to do just that and see how it fits on my Tdi but never really gone and done it yet. The only difference I am aware of is the fact that that the new one is about 2" wider at the firewall and about an 1" wider at the front. This may be a problem if you have 3mm checker plate fitted to the wing tops as it will shut over it and may not clear it. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
