Home > Technical > Rear Door latch
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Rear Door latch
looks like a stud which fastens the rear door latch in has failed to withstand my sheer force of slamming that door.
Are they easy to extract or am I done for?
*pic from google 4.0 V8 Defender 90
My Instagram
Post #1018386 14th Dec 2023 2:22pm
Dinnu
Can drill from inside out and replace with a standard M6 bolt? Careful when the drill bit is about to go through, as I think the bolt is behind the skin (maybe 1” away) and if the drill bit is ling enough you can mark/dent the skin of the door. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1018388 14th Dec 2023 2:49pm
MK
Re: Rear Door latch
*pic from google
Quite easy to remove. You can reach the bolt from the outside. Puma 110" SW
Post #1018390 14th Dec 2023 3:13pm
Dinnu
^^^not welded to the door?
If it was the old style welded door, then it would be easier with a nut plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1018397 14th Dec 2023 3:59pm
MK
I did it on a 2013MY. I have not checked mine (2007) Puma 110" SW
Post #1018401 14th Dec 2023 4:33pm
LJMARSDEN
Thanks for the replies, I'll be tackling it sometime over Christmas 4.0 V8 Defender 90
My Instagram
Post #1019000 22nd Dec 2023 11:33am
