![]() | Home > Technical > Rear Door latch |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
looks like a stud which fastens the rear door latch in has failed to withstand my sheer force of slamming that door.
Are they easy to extract or am I done for? ![]() *pic from google 4.0 V8 Defender 90 My Instagram |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
Quite easy to remove. You can reach the bolt from the outside. Puma 110" SW ............................................................. Earth first. Other planets later |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
^^^not welded to the door?
If it was the old style welded door, then it would be easier with a nut plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I did it on a 2013MY. I have not checked mine (2007) Puma 110" SW
Thanks for the replies, I'll be tackling it sometime over Christmas 4.0 V8 Defender 90
My Instagram |
