Home > Puma (Tdci) > Defender TDCI cutting out.
puma2010
England 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Hi everyone,
just to let you know, I have had an on going problem with my 2.4 puma 90 defender on a 2010 plate. It started to cut out at traffic lights or round abouts very occationaly, after a few weeks got more regular, then finally I could not get off the drive way, it started and ticked over perfect, but as soon as I touched the throttle, Smile it sent it into a frenzey of very uneven tick over and miss fire. The only way to stop it was to turn off and wait a few seconds , then restart , in tick over fine, touch the throttle and all hell let loose, just like fuel starvation. I checked and replaced the fuel filter for a genuine Landrover one, still the same problem. I then looked on this site, to see if anyone had the same problem, yes there was a few, it looked to be the VCV valve [volume control valve] it gives the same or simular simptoms that a faulty injector does. Not a too difficult job, but needs to be taught when fitted, so had to go to Bourton Landrover, I didnt say what I thought, I just told them the simptons and left it to them.
Yes it was the VCV valve, they did the teach on their computer and it ran perfect all the way home. I am now smiling again, untill the next time , not too soon I hope. Smile Smile
Post #1018201 12th Dec 2023 8:21pm
Ianh
Glad they sorted it for you.
Just for future info.. you can fit a VCV and not use diagnostic tools to configure it. Just run the vehicle for a few miles and the ECU will self learn.
Post #1018209 12th Dec 2023 9:51pm
puma2010
Thank you Ianh for the reply, I will remember your advise, would it be the same for the cam shaft sensor on the top of the engine? the reason I ask is becouse I ordered a new one when the Landy was playing up, and it has arrived. Smile
Post #1018219 13th Dec 2023 8:38am
