Home > Maintenance & Modifications > Eberspacher heater install.
excossack
As mentioned on another thread, some pictures of my heater installed.
Erberspacher D2 Airtronic with 801 controller
Control panel
The Carling switch you can see lit up is the main on/off for the heater
Under bonnet fuel tank as I didn't want to break into 25 year old fuel pipes
The fuel pump is mounted to the inner wing.
Clear fuel pipe runs from here along the chassis leg, across the middle x-member and along the inner sill and up to the heater. The heater has a short length of rubber hose to make attaching the fuel pipe to rubber hose easier
Under seat installation
I chose the passenger side to keep the heater exhaust away from the original fuel pipes plus on the drivers side rear seat I keep my winch control and spare gloves along with 1st aid kit and eye wash
Heat output is via a metal tube into a swivel vent - this needs reattaching to the seat frame (but this does stop the tilting of the seat frame without removing the tube first.
Air intake is facing towards the door and sort of recycles the warm air to save heating cold air from outside.
Underside of the heater
The underside of the heater showing, the fuel pipe in, exhaust out and combustion air intake
The combustion intake is hiding behind this removable panel and has an airfilter. The filter head rests on top of the chassis rail and is cable tied in place.
Airfilter
Hope this helps. Any questions please ask! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1017413 4th Dec 2023 4:07pm
MadTom
TD5 in tank fuel pump has provision for Webasto fuel pick-up. If you have hatch to look onto the pump in car, you can add needle in tank without disconnecting fuel lines.
Do you have some muffler on the heater exhaust? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1017584 6th Dec 2023 7:44am
excossack
Hi MadTom
I don't have a hatch to get to the fuel tank.
No silencer/muffler on the exhaust - its a straight through for that added Eberspacher exhaust note Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1017594 6th Dec 2023 9:23am
MadTom
Fuel pump hatch is very usefull, especially when using car for long distance travelling. I made it to several frieds Defenders, and at least two of them used in somewhere outside to replace broken pump. They were really happy not dropping tank somewhere outside, nearly full of diesel. Spare pump (just the internal part) is small spare part, I cary during our trips. Discovery 2 has the hatch from factory.
In our Discovery 2 I have Webasto Airtop 2000, and without exhaust muffler it was a bit like small jet engine - noisy. Muffler - original from Webasto made a big difference. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1017680 7th Dec 2023 7:23am
excossack
Mine sounds like a small jet plane, its not too loud but does allow me to remote monitor (by ear) from the house to make sure its working on cold mornings Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1017685 7th Dec 2023 9:54am
