![]() | Home > General & Technical (L663) > A Pillar lower cap removed/stolen? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3004 ![]() ![]() |
That's bizarre, they're quite difficult to remove and that's with the door open so you can prise the part off from the inside edge (lt won't come off from the outside without breaking)
Unless they changed the design for my 2022. l can't see why anyone would need to steal one either. They don't fall off in normal use. Perhaps they wanted the large A pillar trim, which does fall off, but got disturbed. |
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 ![]() ![]() |
Hi. I had exactly this happened to me. Replaced under warranty by my dealer. Apparently there was a redesign of the A-pillar cover and the lower clip on cover due to them been prone to pinging off. L663 D300 SE MY22.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1258 ![]() ![]() |
BritCar have them for a GRAND price.
![]() https://www.ebay.co.uk/itm/296061536788?ha...R8jEqqz-Yg |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1107 ![]() ![]() ![]() |
Those stickers now come in a modern design to match the New
![]() ![]() Click image to enlarge |
ckamps Member Since: 04 Jul 2023 Location: Oregon Posts: 45 ![]() ![]() |
See a thread below containing part numbers for the redesigned parts. Note that the three parts on each pillar designed to work together. I.e. be careful about mixing matching generations of the parts.
If your Defender is a bit older, some people including myself have had luck asking Land Rover dealers to replace all three parts on each pillar under warranty. https://landroverforums.com/forum/2020-def...rs-118556/ 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
Skippy76 Member Since: 05 Apr 2021 Location: Surrey Posts: 16 ![]() ![]() ![]() |
Thanks for all the replies guys, will hit my dealer up as they are just about to replace the seat covers
